labview
hi,
I am doing transient state analysis of 3-ph induction motor. In it, i want to plot the transient state line current(RMS) and speed with time using labview.I am not being able to find a way of taking the readings continuously. Please help!!
I am using current sensor(LA-25-P), Card NI PCI 6221 and connector block SCB-68.
(2,590 Views)
First, I would really recommend a less generic post title. Since this is a LabVIEW forum, every single post is about LabVIEW. 😉
What is your definition of "continuously". What have you tried? How did it fail? Can you show us some code?
(2,581 Views)
I seem to remember a time recently where there were about 8500 posts completely unrelated to LabVIEW on these forums Smiley Tongue
(2,571 Views)
Next time onwards, i will be more specific in the subject!!!
I am glad that i was able to find a way out by my own for my querry yesterday. Now, its working.. Smiley Happy
But now i have stuck wid something else....
I am simply taking the inputs using DAQ and measuring their RMS values. The RMS that i obtain varies and does not stabilize but when i measure it manually with a flukemeter it shows a stable value. For example, if flukemeter is showing 2.123A current, then RMS shown will vary from 1.9 to 2.3A. I there anything I could do to stabilize the RMS. Taking mean does not make sense.
(2,541 Views)
Are you taking complete cycles of the signal you are monitoring?  Is it a sinusoid?  If you aren't taking the RMS of a complete cycle or multiple complete cycles, then the RMS of what you are measuring is going to change as the you roll through the phases of the signal.
(2,539 Views)
Yes i am taking complete cycles as input and signal is a sinusoid
(2,507 Views)
