labview xy graph plotting
Hi there,
I'm trying to generate an x-y graph with function inputs for x and y to create a circle. I just can't seem to get the graph to show up though. Would somebody please be able to lend me a hand with this?
I've attached my VI to show you what I have so far.
Thank you kindly,
James
(2,908 Views)
Accepted by topic author JCG77
A graph requires multiple points, so you're just plotting a single point at a time, not the whole circle. You need to generate a set of points to graph it.
Cheers
--------,       Unofficial Forum Rules and Guidelines                                           ,--------
          '---   >The shortest distance between two nodes is a straight wire>   ---'
(2,892 Views)
Thank you for your help
(2,879 Views)
