09-01-2014 08:26 AM
first download LIFA as crossrulz suggested.
If you want to just use LabVIEW not Arduino sketch.
Or you can use VISA.
You can write your own Arduino sketch or use any example that are included in Ardunio IDE.
Which send or recives serial characters and gives some meaning full results.
and then in LabVIEW read or write serial characters using VISA.
09-02-2014 02:01 PM
Begin by downloading the LIFA project. Spend some time exploring the included examples and the LabVIEW code inside all of the LIFA functions. Also spend time looking at the included Arduino sketch. You will begin to see how they have done the architecture of the system, and realize that it is not very complicated. Even so, at least the groundwork has been done for you and you are free to extend it as necessary.
Once you are familiar with the code, you can design your interface to do whatever it is you need to do. Select an Arduino with capabilities that match your project. Maybe a MEGA or Uno is all you need. You can use any Arduino hardware that the LIFA sketch supports, or modify it to meet your requirements. From there, it's all about adding functionality to your interface. The serial data transfer details are taken care of by the LIFA code.
09-02-2014 02:09 PM
Thank you.
I have already bought an arduino mega2560 and i have also downloaded LIFA project also LINX and i have tried a lot of stuff with these things.
i think i had found one video few weeks ago when i was struggling to learn arduino with labview, are you asking me to do something related to this stuff :
09-02-2014 02:16 PM
My Portuguese is a bit rusty (read: nonexistent), but yes, he seems to be using VISA to do serial communication. But I am saying that LIFA uses VISA under the hood already. All you have to do is use the LIFA VIs to do more high-level actions such as read digital inputs, set analog outputs, etc.
09-02-2014 02:32 PM
but even if i use digital read, digital write, etc. high level functions, i need to send data to the board serially to do the processing. Right?
like in that video..
09-02-2014 02:58 PM
09-02-2014 03:01 PM
not exactly signal processing but just some comparison but it should be in real-time that's why i am pressing more upon the point of processing on the board.
09-02-2014 03:10 PM
What is real time to you?
09-02-2014 03:11 PM
09-13-2014 01:13 AM
Thank you for your help with the topic of discussion. As suggested by you, i tried coding in arduino and its running successfully, i mean i am able to do what i wanted to. But i need your help for the second part, i am trying to communicate serially to arduino board through labview but i need labview as a front panel where i need to change values of two variables used in my arduino code.
The difficulty i am facing here is that i am not able to understand how can i make the board recognize that the values coming from labview are two values for different variables so that i can do a check in my code which will automatically change the values of those corresponding variables in the code.
I am posting a link here in which they have done serial communcation but it is taking only one value.
http://physicslight.wordpress.com/2014/07/14/arduino-labview-serial-write-read/
Thanks in advance.
