04-25-2014 06:09 AM - edited 04-25-2014 06:29 AM
Hi Luke,
Resurrecting this old thread, I have tried the method you describe, but not having much success.
I can see the correct ProviderID in the registry, I can see how it should be re-shuffled to get the GUID, but I cannot actually run the command you described.
I have tried by coping the GUID directly from the nimdnsNSPTool.exe -list output, but it does not seem to work, I get FAILED (10013) response. Do you have any tips on what may be wrong here?
EDIT: it seems I have to run this from a command prompt that has been opened with Administrator priviliges
04-25-2014 07:51 AM
Hey Neil,
Did the workaround end up being successful?
08-17-2014 04:38 PM
SUper simple answer via VIDEO!
https://www.youtube.com/watch?v=asAvRUq9FiE
Totally works!
If you like it please LIKE the video and if you know something ELSE please make a reply and a video to show us how to fix this problem..
How many other folks out there long for LabVIEW 6.1, the FAASTEST, most efficient cherriest version of LabVIEW EVER!!??
08-17-2014 04:42 PM
Dang! Ieft out stuff in the bottom of the video that folks often do not notice..
How to fix slow boot times on LabVIEW
I learned this from Britton and Luke at NI and put it all in a video so anyone can refer to it should they need it in the future.
If you find this video useful please "LIKE" it by ticking the thumbs up icon...
Here is my Cheat Sheet for your use...
Go to Windows and search Services
Click on gear
Sort by name
FInd these three and Right CLick Properties and select Automatic Delay Start
NI Device Loader
NI Service Locator
NI Configuration Manager
Microsoft Security Essentials is the AV on this 64 bit PC..
We will want to add National to the exception so it does not spend time checking it out.
Settings/Excluded Files and exceptions.
Add NI folders here:
C:\Program Files\National Instrument
and
C:\Program Files
(x86)\National Instruments
How to look at the LOG...
Start/ and search Event Viewer
Then Applications and Services Logs
Then Microsoft
Then Windows
Then Diagnostics-Performance
Your full path is this:
Applications and Services Logs/Microsoft/Windows/Diagnostics-Performance
04-13-2015 06:53 AM
Nice to see that this problem got "priority" in 2012 (http://forums.ni.com/t5/LabVIEW/labview-runtime-slow-pc-start-up/m-p/2263060#M716777). Today is 2015 - and it's still present and can be solved by the same method (disabling the NI mDNS component).
11-28-2015 05:10 AM
I can also confirm this registry fix. I use a lot of virtual machines, and it took me a long time to track this down. It started manifesting on a LabVIEW 2012 virtual machine, but it was inconsistent across several instances of that VM on various hosts. It also happened on LabVIEW 2013 and 2014 VMs, again, inconsistently across various hosts. Even after thinking I fxed it, it would re-appear.
This registry fix definitely did the trick. The symptom was slight different on a VM using VMWare Player. I experienced that the VM would boot as normal (fairly quick), but the Start Button/Orb and taskbar were missing for about 15-30 minutes, and then would eventually appear. After implementing the registry fix, I have rebooted various VMs on various hosts and have not seen the problem again.
02-04-2016 02:36 AM
Breating some new life in this topic I come here with the concluding answer (especially for 64-bit):
The executable to use is nimdnsNSPTool.exe
These lines you can include in your deployment:
"C:\Program Files\National Instruments\Shared\mDNS Responder\nimdnsNSPTool.exe" -remove "981DF75B-898E-4c0c-B01C-5F181F817889"
"C:\Program Files (x86)\National Instruments\Shared\mDNS Responder\nimdnsNSPTool.exe" -remove "981DF75B-898E-4c0c-B01C-5F181F817889"
This will remove both instances of the problematic Service and make sure you can log out and in in an orderly fashion.
Cheers!
03-18-2016 02:47 AM
I would love to use this method because we are installing 70 computers in the next weeks and always have to do a manual regedit afterwards.
Where can I include those lines in the deployment? I did find "Start program after installation", but i can only start one program and have to include this program into the project. Is there anything I'm missing? Using LV 2013.
03-18-2016 07:16 AM
depending on how you need to run them, you may be able to string together a couple executables in a batch file:
http://digital.ni.com/public.nsf/allkb/ED185175604CAA86862579BA00593002
04-28-2016 01:14 AM
We are using these lines in our installation:
(this is just a small part of the installation script)
:: Removing nimdnsNSP
set nimdnsNSPTool=National Instruments\Shared\mDNS Responder\nimdnsNSPTool.exe
if not exist "%ProgramFiles%\%nimdnsNSPTool%" goto nop
echo .
echo Removing nimdnsNSP
"%ProgramFiles%\%nimdnsNSPTool%" -remove "981DF75B-898E-4c0c-B01C-5F181F817889"
if not %errorlevel%==0 goto error
if not exist "%ProgramFiles(x86)%\%nimdnsNSPTool%" goto end
echo .
echo Removing nimdnsNSP (32-bit instance)
"%ProgramFiles(x86)%\%nimdnsNSPTool%" -remove "981DF75B-898E-4c0c-B01C-5F181F817889"
echo Done!
goto end
