01-28-2015 12:07 PM
i'm new to LabVIEW OOP.
Is there a way to get a variant control in the "Cluster of class private data" for a class? If not, is there an alternative for handeling variant data? I'm using LV 2013.
Thanks.
01-28-2015 05:16 PM
You just use a variant control and put it in the big giant cluster. It is the same for any other data type. Is there a specific issue you are running into?
01-30-2015 11:48 AM
Using the search function, i've found it!
