05-26-2008 03:58 AM - edited 05-26-2008 03:58 AM
05-26-2008 05:02 AM
05-26-2008 05:28 AM - edited 05-26-2008 05:32 AM
It's extremely hard to understand what you are exactly doing. Not passing parameters seems like a defnitive error to me but I might misunderstand what you are doing. Showing your code both how it works and how you try it when it doesn't work would definitly help a lot. Putting up the actual VI with an example of what you try to do would be best.
MScap wrote: Sir, I have made sure that the strings are defined with a minimum length. The array size is connected to an other input(no of steps). As i said earlier, the vi runs fine, without crashing, when all the input parameters are passed. If i do not pass even one parameter, i should get an error message (of max 412 characters). I get this error message and then LV crashes.
Well I see you got it solved. What I told you in my previous post was in fact the same as what Andre told you later on in a different way.
MScap wrote: Thank you so so so very much sir!! We had been worrying over this for a week!! As of now its running fine, without crashing!!
05-26-2008 05:38 AM
