Using LABVIEW 5.1 and multi-function DAQ board CB-68LP, how do we make the DAQ board output a voltage to actuate a circuit? What pins do we use and what "vi" will give the correct output to the desired pin? We have been able to monitor input and get a desired output using the National Instruments Test Panel and channels 0 and 1 (pins 21 and 22 and ground pin 55) but we are unable to get a continuous monitoring and output based on the monitoring using LABVIEW itself. In addition, using the test panel, we have been able to get the desired output using the digital i/o.
