02-25-2015 09:15 AM
My VI runs and I have no problems.
If I stop then Vi and re-run it, pretty much every second time it crashes. It does not point to anything and the only message I get is:
Problem signature:
Problem Event Name: APPCRASH
Application Name: LabVIEW.exe
Application Version: 13.0.0.4051
Application Timestamp: 525595c6
Fault Module Name: NiViPxi.dll
Fault Module Version: 5.4.0.49152
Fault Module Timestamp: 51c243ad
Exception Code: c0000005
Exception Offset: 0000bbe0
OS Version: 6.1.7601.2.1.0.256.48
Locale ID: 6153
Additional Information 1: 0a9e
Additional Information 2: 0a9e372d3b4ad19135b953a78882e789
Additional Information 3: 0a9e
Additional Information 4: 0a9e372d3b4ad19135b953a78882e789
Read our privacy statement online:
http://go.microsoft.com/fwlink/?linkid=104288&clcid=0x0409
If the online privacy statement is not available, please read our privacy statement offline:
C:\Windows\system32\en-US\erofflps.txt
This only clue in the above I can find is NiViPxi.dll
I am using a PXI rack so maybe it is to do with one of the devices?
I would be nice to have more clues, does anyone know why labVIEW keeps crashing?
Rgds,
Sean
Solved! Go to Solution.
02-26-2015 06:01 AM
Hi SeanJ,
I have a few questions regarding your issue:
- Does the crash only occur when you re run this particular VI that you are talking about?
- Is there any crash logs generated?
- What does your VI do?
- Would it be possible to show the code?
02-26-2015 06:14 AM
Hi jinfone.t
I managed to root cause it to a netway 72 PXI dll and have fixed the issue, (took a lot of effort!)
Yes
None that I know of apart from the output I pasted on the screen. It's possible there is something in the event monitor
It function tests our product, (IOT)
