01-27-2015 05:17 PM - edited 01-27-2015 05:34 PM
Hello All,
I have used the basic tutorial for the NI Wireless Sensors Network. http://www.ni.com/tutorial/8890/en/. I have completed it with one node. The next step in my project is to send the data from the node and the date and time to an excel file every hour. Are there any tips I can get for atleast sending the date and data to the excel file? I am using labView 2012
I edit it because I put text file instead of excel
01-27-2015 05:32 PM
01-27-2015 05:35 PM
I tried to have it write to excel but the wires will not connect. I am not in the lab currently but I will put a screen shot up tomorrow to give a better idea of what is going on
01-27-2015 07:39 PM
Please post your actual code instead of a screenshot. It's easier to work with.
01-28-2015 11:46 AM - edited 01-28-2015 11:47 AM
Hey Pgray,
You should be able to right click on the IO Node from the end node on the host and enable time stamps. As Dennis mentioned using a write to spreadsheet will be easiet.
First figure out the structure of your spreadsheet column 1 being time stamp, column 2-5 being node 1 channels 0-3, etc...
You probaly need to convert the numeric values to a string, you can use the format into string function. You'll need to do a similar step for the time stamp. Then you'll be able to bundle the strings into an array and write to the spreadsheet and it will map as a row.
Hope this helps.
01-28-2015 12:23 PM
Why wont the wire connect
01-28-2015 12:43 PM
