02-12-2007 11:16 AM
02-12-2007 12:42 PM - edited 02-12-2007 12:42 PM
I don't know what you mean by "no writing and reading VIs". There is the GPIB Write that sends the command to the instrument. I haven't used this instrument but if you want to increment the voltage, can't you do that by changing the value you pass to the 'VOLTAGE' input? Put this function in a loop. Your step values could be an array or from a shift register that gets incremented, etc. Unless the instrument has a command that supports some sort of sweep operation, you have to do it in your program. Check the manual for the instrument.
Message Edited by Dennis Knutson on 02-12-2007 11:42 AM
