I would like to perform 40 piece 4-wire resistance measurement. (20 at a time) using the 2700 with 2 X 7702 cards.-GPIB connection.
What should be the Channel List to read one 7702 and then the next 7702.
Will 101:120 work for 1st 7702 and 201:220 work for the 2nd 7702.
Kindly help.
Also i need to poll the idle state bit in Keithley 2700.
I got the SCPI command to read the Operation Event Register that contains the Idle bit is :STATPER?
How can i implement that in labview?
Kindly help.
Thank You in Advance.
Regards
Grugh Mike
Success is Everything !!
