Hi frog7,
It sounds like your program that 'matches a template image to a full video' would be a good place to start, unless I misunderstand what this program does. Can you post this code so that I can take a look and perhaps give you some pointers on how to adapt this code to achieve the new functionality that you need? I'm assuming that you are using the Vision Development Module for LabVIEW 2010 as in your previous posts. Also, for future reference, it would be better for you to post this question in the Machine Vision boards. Thanks!
Joseph S
