03-19-2007 10:43 AM
03-19-2007 10:52 AM
The error is stating that one of the VI's in your application cannot be compiled. (it has a broken run arrow)
Try this. Open your top level VI and make sure it can run. If you are calling subVIs dymanically, open them as well and make sure they can run. Hold down the Ctrl and Shift keys and click the Run arrow. This will recompile every open VI. Go to the File menu and do a 'Save All'.
Try to build your application again and let us know what happens.
Ed
03-19-2007 12:39 PM
Thanks Ed,
The full issue is the when I try to build my Application, I gives my this error of a VI that is in the FPGA portion of the project. This portion seams to do an FPGA compile and even RUN. My Application refers to a Host VI that opens a FPGA reference, which is part of the FPGA portion of the same project file. The problem VI is not even refered directly by the Host side.
One good question I would have is why does the host side even care about the low end VI inside the FPGA?
03-19-2007 12:41 PM
Sorry I may have forgot other key information. I am running LabVIEW 8.0. Also my host applicaiton runs as best I know.
Mike
03-19-2007 01:00 PM
