02-08-2015 09:35 AM
we recently bought two Xcelera-CL+ PX8 frame grabber cameralink cards from teledynedalsa. we have a fast camera Bonito from AVT
I wounder if there is any way I can use Labview to talk to them?
thanks for your time
xg
02-23-2015 08:17 AM
Hi xg,
Have you seen the below link? It shows all of the current NI Supported Cameras.
http://sine.ni.com/apps/utf8/nipc.get_camera_list?p_camera_status=C%22
02-23-2015 08:25 AM
Many Thanks. Al C
Well, it looks that there is no driver
02-23-2015 08:52 AM
02-23-2015 09:43 AM
thanks, Dennis.
>vendor? Have you looked at the api from them so you can write your own?
the vendor provided a Microsoft Visual C++ API, but not DLL. Below is what stated in the manual if I want to write my own applicaton in C
if vendor provides a DLL and H file, I know how to import into LabView, but, what/how to do with *.lib?
any suggestion is more than welcome
cheers
xg
Header Files and Libraries (C API)
The following files are provided for building C applications with Sapera LT.
File Name |
Description |
Location |
corapi.h |
Main header file |
Sapera\Include |
corapi.lib |
32-bit C library for Visual C++ |
Sapera\Lib\Win32 |
corapi.lib |
32-bit C library for C++ Builder 2006 and up |
Sapera\Lib\Win32\Borland |
corapi.lib |
64-bit C library for Visual C++ |
Sapera\Lib\Win64 |
02-23-2015 12:00 PM
02-23-2015 03:45 PM
They didn't provide any type of binary for communicating with their hardware? Remind me not to use them I guess.
Also that can't be the exhaustive list of cameras that work with IMAQ is it? Is there some APIs that just work if the frame grabber supports it like DirectShow? And I know I'm using a frame grabber that isn't on that list that is GigE. All I'm getting at is, is it possible that IMAQ will work with this frame grabber if Windows has the drivers?
Get going with G! - LabVIEW Wiki.
16 Part Blog on Automotive CAN bus. - Hooovahh - LabVIEW Overlord
02-25-2015 05:58 AM
Ok, I will try. thanks
02-25-2015 07:20 AM
thanks.
this is fast camera not GigE one. it uses serial communication, the frameGramber card uses a Serial-Over-Camera Link port to talk to the camera's firmware through clsercor.dll. The frame graber driver is called vedio interface driver (CVXceleraCLpPX8.vin). I checked with NI support engineer, no solution yet.
02-25-2015 09:33 AM
