06-18-2015 01:58 PM
I just purchased 2 cRIO 9067s and I'm trying to configure one of them to use. I got the IP address set and booted it into safe mode. The status light blinks twice, then pauses. The documention says this means I need to download software. NI MAX only suggests using versions 14.?, which I'm assuming is LabVIEW 2014, but that option is grayed out. And if I try to do a custom install, everything in the list produces a concfict and wont download. Is the 9067 only compatible with LV 2014? Or am I missing a step? the version of LV that I am using is 2013. I'm installing 2014 to test this theory, but I'm no thopeful. Thanks for the help people.
Solved! Go to Solution.
06-18-2015 03:05 PM
The cRIO-9067 does require LabVIEW and NI-RIO 2014. You can use http://download.ni.com/pub/gdc/tut/crio_software_versions.htm to look up the minimum software support for cRIO products.
I don't see how I can link directly to the result, but if you select "CompactRIO Chassis and Controllers" from the drop down and then "cRIO-9067" you should see this table.
Software | CompactRIO (FPGA Interface) | CompactRIO (Scan Interface) |
✔ Supported | ✔ Supported | |
LabVIEW | 2014 | 2014 |
LabVIEW FPGA Module | 2014 | — |
LabVIEW Real-Time Module | 2014 | 2014 |
Device Driver Software | NI-RIO Device Drivers August 2014 | NI-RIO Device Drivers August 2014 |
NI-DAQmx | — | — |
Other Minimum Software | — | — |
06-18-2015 03:45 PM
That answered my question. Thank you.
