03-29-2015 09:34 PM
Can you post a copy of this code that you are using, which is now generating an error code 60?
Also a description of your network setup would be good:
03-30-2015 03:28 AM
I would imagine that it's probably because another application is also listening on the port. You should be able to run a netstat command in a windows command prompt to find out the name/process ID of applications using the port to check whether or not it's in use.
04-01-2015 02:24 AM
All i know is that the IP addresse is 192.168.0.2 and this is the code.
04-01-2015 06:38 AM
Is that the IP address of your computer, or of the sensor? How did you confirm this address?
Can you save the VI for LabVIEW 2013 and reattach?
