interfacing labview with relays
Hello
Could someone please tell me how could I interface labview to an relay in the external hardware to switch ON/OFF the path of a circuit. Thankyou in advance...........
Regards
Message 1 of 9
(2,972 Views)
you need some DAQ hardware...
Message 2 of 9
(2,971 Views)
could you please tell me what kind of DAQ hardware device can I use......
Message 3 of 9
(2,965 Views)
you could use any hardware that allows to output digital signals. The cheapest from NI might be the USB6000…
Message 4 of 9
(2,960 Views)
MCCDAQ has the least expensive DAQ's, or you could pay more and have the relay bult into the board (http://www.mccdaq.com/solutions/USB-Digital-IO-High-Voltage-Solutions.aspx).
You could try using the parallel port with LabVIEW, I saw this work many years ago.
You should know that unless the board is built with the relay installed like the link above, you will need to amplify the signal so that it can drive the coil.
Message 5 of 9
(2,954 Views)
I like to use the PCI/PXI-6009 DIO card (96 DIO!) to control relays.  That card can put out enough current to turn on a transistor that will then turn on a relay or drive a SSR directly (depending on how much current the control needs).
GCentral
Message 6 of 9
(2,925 Views)
For those on a budget I usually recommend an Arduino Uno.  You can usually find them for under $30, sometimes under $20.  Then you load up the LIFA toolkit by NI, and you've got your self a bunch of DIO, a few AI, PWM, SPI, I2C, and a few other basic features.  Again you won't be driving relayes directly with this, each pin has a very low current capability.  You would have some kind of buffer circuit that could drive a mechanical relay.
Message 7 of 9
(2,913 Views)
Thanks alot......Actually I am using GPIB  as the DAQ hardware to interface labview with my test circuit, in which I am using relays for switching purpose........ is it possible to use the same GPIB  even to interface the relays with labview ?
Best Regards
Pratheek
Message 8 of 9
(2,884 Views)
Accepted by topic author pratheek
GPIB is not DAQ hardware. If you have a GPIB instrument that has some sort of switching, you should have mentioned that in the first place and if you want help in controlling this instrument, provide the make and model. I would also hope that you've already checked for an instrument driver by using Help> Find Instrument Drivers.
Message 9 of 9
(2,877 Views)
