06-02-2016 09:25 PM
I am developing a LabVIEW VI for a test and measurement system to be used on an Advantech PCM-4386F that has two MPC560 data acquisition cards from MicroSys Inc. The method that I have used in the past is to develop and build the VI on a desktop PC than downloading the VI to a target system to test and try to debug it. Is there a way to develop the VI on the PC then interactively with the PC being the controller test and debug the VI that is running on the target system?
06-02-2016 09:33 PM
Are you deploying a VI to the other PC, or an executable?
With an executable, you can make a debuggable executable and connect to it from your PC using a Remote Connection (under the Operate menu.)
06-03-2016 10:32 AM
I am generating an executable to run on the target. What documentation is available describing the process of making a debuggable executable and using a remote connection from the PC to operate it?
06-03-2016 11:22 AM
Hi Mike,
See below.
Remotely Debugging Executables in LabVIEW
http://digital.ni.com/public.nsf/allkb/8DA679805915DE40862572D5007B2F70
Have a great day!
Finch Train
