04-14-2016 06:02 AM
I'm trying to modify the color scale of the intensity graph I'm using to display a 2D array of I32
I tried following various suggestions, but I cannot do it.
I also downloaded the support VI "Intensity_Colors.vi" from NI: in that case I have no problems at right-click on the scale label, and see immediately the effect.
In my case instead:
you can see I'm selecting RGB=200,0,43, but my scale remains fixed in grayscale.
The same happens with "interpolate colors" switched on or off.
What am I missing?
thank you!
alessandro
04-25-2016 07:37 AM
have you tried to change the color of the 2048 marker or only the marker color on top and on bottom?
sometimes the markers are shifted out of the scale and then you wonder why nothing changes.
try to drag the bottom or top marker nearer to the center so you see if come hidden markers appear.
04-29-2016 02:17 AM
I tried but it didnt help.
I noticed however that by clicking exactly at the top (bottom) level of the scale I'm able to change the color there:
but it changes the color only there.
If I deactivate "interpolate color", the only effect is that the grayscale changes to all-black
alessandro
