06-11-2012 08:13 AM
I was trying to connect TEC-9100 to Labview but I couldn't find the right driver. I tried to in IDN no luck.
Solved! Go to Solution.
06-11-2012 08:21 AM
You mean IDNet? You're right, there isn't one. That device apparently uses Modbus, so you can use the Modbus library to talk to it.
06-11-2012 11:32 AM
I am very new to this Labview, and I have try to communicate this modbus with labview but I couldn't. Can you suggest a good place that I can start from scratch?
Thank you
06-11-2012 12:22 PM
Did you read over the document for which I provided a link?
06-11-2012 01:20 PM
Yes I have read that and tried to add some examples following this link
file:///C:/Documents%20and%20Settings/gebiurg/Local%20Settings/Temp/readme.html
and this
http://zone.ni.com/devzone/cda/epd/p/id/4756
So far no luck.
06-12-2012 10:51 AM
Your first link points to your hard drive. Unless you want us to hack into your computer, we can't see this.
Define "doesn't work". What did you try?
06-12-2012 01:18 PM
Now I have added the Library. I can see modbus. Here is where I am and stuck. I have connected the TEC-9100 to PC using RS232 connecting to RS485 adapter. I am confused now what to write so the LabVIEW can communicate with this device. I was trying to use VISA Open, Write, Read and Close. I guess I am in the wrong way.
Thank you for your help
06-12-2012 01:22 PM
Is it really that hard to Google 'LabVIEW Modbus tutorial'???
06-12-2012 01:44 PM
It might be hard for you :). I guess you just logged in wanna say whatever you want to say. If you don't have a specific answer for it just at least be just gentle. Please try to Google how to be gentle.
06-12-2012 01:48 PM
Its tiresome when people don't make an effort to help themselves.
