installer overwrite
I created 2 different installers for 2 different programs. I want them to reside in the same target folder. However, when I install the second program, it overwrites (replaces) the first one. The 2 programs have different names. How do I prevent this?
(3,189 Views)
Did you duplicate the installer, there's an 'upgrade code' that identifies the application for things like checking if it's a fresh install or an update. You can generate a new random upgrade code from the installer build specs (it's under version information).
If that doesn't work, then it's possible that they can't reside in the same folder. I don't know how clever the installer that NI uses is, but it might delete the folder when uninstalling. If you put it into a subfolder in the directory though, that should be fine.
(blog)
(3,181 Views)
I did not duplicate the spec in the project but I copy and paste then rename the entire project to a different one because they are so similar. I will try to generate a new upgrade code.
I did try to put it in a different target folder but it still goes back and uninstalls the old one before installing the new one. I have a completely different program in the same folder and it does not have this issue.
(3,161 Views)
Then yes, it's definitely because of the Upgrade Code - if the upgrade code is the same then it considers it to be the same application so it will uninstall the old files before installing the new files.
(blog)
(3,157 Views)
Accepted by topic author sng99
Generating a new upgrade code fixes the problem
Thank you very much
(3,148 Views)
Why not kudos my post or mark my suggestion to generate a new code as the solution, then? 🙂
(blog)
(3,098 Views)
