hello,
I build an interface to a serial device that is connected through USB-RS232 cable
( I had to install profilic windows driver for my computer to identify the cable).
I did that and my VI works.
I build an installer with run-time enviroment to be installed on another computer.
(who has profilic drivers installed allready - the compter communicate with the device via hyper terminal and I build the LabView for it).
when I install and load it - It does'nt identify the coms - I suspect I need to install device driver which is something my compter have and the other one not.
Can someone help me on what check box I need to check when building the installer?
