10-22-2015 05:49 AM
I am installing labview 2013sp1 on a brand new computer with win7-32bit OS, but keep getting Windows SDK error(code -12, and something else).
10-22-2015 05:55 AM - edited 10-22-2015 05:55 AM
Are you installing from the discs or from the network? I've I think I've seen that error code before when trying to install from a network path. Try copying the installers to your local machine and then running the installer.
10-22-2015 08:05 AM
I know for a fact that installing LabVIEW 2013SP1 on Windows 7 32-bit from NI DVDs works.
10-22-2015 09:15 AM
I install it from hard disk which is copied from the NI dvd disks.
10-22-2015 09:17 AM
Try installing it from the disks, or create an ISO image of the disk, mount the image and then install from that. This sounds very similar to the issue I had.
10-23-2015 08:01 AM
Thanks.
Today it is successfully installed from DVD disks, but failed from ISO image which is created from the same disks.
Weird.
WT
LV2013sp1
