07-14-2010 10:54 AM
I am trying to install the labview 2009 run-time on a computer that has no NI software of any kind installed.
I am logged into the computer as administrator and the machine is a windowsXP system with plenty of hard drive and memory. I get the follwoing error message:
This says something about Windows Installer is not correctly installed. I then went to the microsoft website and downloaded and re-installed windowsxp installer. Then, re-tryed to install the NI Labview 2009 run-time, with the same results.
What do I try next?
Thanks, bberks
07-14-2010 12:28 PM
Did you try re downloading the LabView Runtime engine? I would try this and see if it works.
07-14-2010 01:41 PM
I also try re-downloading the run-time from ni.com full and small install versions. Both have the same results with the same error above discribed.
07-14-2010 01:50 PM
That's a Windows error, so you should look over this Microsoft KB article: http://support.microsoft.com/?kbid=315346.
Just to rule it out: are you running 64-bit?
07-15-2010 09:15 AM
I am using WindowsXP SP3 32bit
I did try all the steps in http://support.microsoft.com/?kbid=315346 but I am still getting the same error when trying to install the 2009 run-time 32bit version.
Any other suggestions?
07-15-2010 10:54 AM
I just want to clarify that you tried to Method 1 and 2 in the Microsoft KB. You tried both reinstalling and reregistering the Windows Installer?
07-15-2010 11:17 AM
Yes. I tried both methods.
Thank you for any help or ideas....
07-15-2010 11:40 AM
What versions of the Windows Installer did you download? The version linked to the Microsoft KB doesn't support XP SP3. Version 4.5, however does support that service pack.
07-15-2010 01:39 PM
My windows is XP Pro SP3, and installer 4.5. This is the latest updates from windows update website.
Sould I use a different version?
07-16-2010 01:47 PM
That version of the installer should be fine. Have you confirmed that the installer service is running as per this Microsoft KB # 324516.
