09-12-2006 12:45 AM
09-13-2006 11:04 AM
Hi astrophysics,
I've looked at your program and have some questions. What exactly is this weird behavior that you are referring to? Can you explain what you are trying to do and what the program is doing instead?
Also, you said that you were looking for ways to debug your program. Inherently, LabVIEW has many debugging tools, such as the probe tool, which allows you to check wire values and highlight execution, which can narrow down the specific location that is giving these unexpected results. You can also check LabVIEW Help - the topic "Debugging Options Page" explains the available tools.
Let me know how it goes.
Janell Rodriguez | Applications Engineer | National Instruments
09-13-2006 11:08 AM
09-13-2006 11:12 AM
09-13-2006 07:12 PM
Hi All, Thanks for your reply. I have tried ways to debug the program. Actually the vi works fine with the keyboard and barcode scanner.
But not the exe one. When exe is run, after the entry in input1 is given, suddenly "j" appears in input 2. I could not find the source of "j".
I will check with the programmedbarcode scanner. The barcode scanner shares with the keyboard.
Anyway thsnks for your great help.
Clement
09-14-2006 03:46 PM
HI Astroboy,
Let us know what happens after you check with your barcode scanner. Remember, we are here to help!
