Hi Brett,
well, the sav-gol.vi is inside a case structure as an option to filtering. I have other techniques in other cases. So the way it runs:
1. the progrma is running...2. In one case structure I have options for data linearisation using a number of techniques, 3. then in second case structure there are options for filtering the data e.g. the savit-golay.vi, 4. in a third case structure there are options for detrending.... Now everytime i want to import a file i press the 'get file' bolean and the program outputs the signal with the selected proprocessing methods from each of the case structures. The problem with the savitz-golay.vi is that it needs reinitialisation everytime I 'get file'. If the program stopped after each 'run' then it would not be a problem but becasue I have a while loop to run the program continuously, there is the initialisation problem so I am not sure how to trigger the initialisation of the savit-golay.vi without having to press the initialisation bolean everytime or stopping the program. There should be a way to initialise this vi every time i press the 'get file' bolean. I hope that this explains thing better. i appreciate your help.
RVR
