02-04-2010 12:53 PM
Has anyone seen this problem before. I have an index array that I have used before in an earlier subVI but for some reason I'm getting a wiring error and I'm not sure why. I have attached the earlier use and the current useage and I can't see why I'm getting an this wiring error. The input is an 32bit unsign and I'm moving the lower picture function to a different program (no cut and paste).
If you have any ideas please let me know.
Gary Tyrna
Solved! Go to Solution.
02-04-2010 12:56 PM
02-04-2010 01:09 PM
Darin,
Thanks for the heads up. I'm looking to pass the memory map information into my state machine but I'm not sure how and I have been giving it some thought. I'm using the local to get the loop up and running (first state machine) so I'm using this as a learning platform.
Gary Tyrna
02-08-2010 08:30 AM
Gary,
In general, if you're going to be passing information in a state machine from iteration to iteration, using a shift register to do this is the best choice. If you have multiple pieces of data that need to be passed, you can use a cluster for this so that you have fewer shift registers.
