12-18-2014 08:37 AM
@chilemad wrote:
my mind is blown! lol so feeding the temp into the register only takes the value into account once?
Shift registers often seem confusing the first time you run into them but, they are fairly simple. Both the input and output tunnels represent the same memory space. So they work great to pass data from one loop iteration to the next.
The latest code that blows your mind works like this:
Temperature (from the terminal) is passed to the first while loop iteration on the SR. Iteration 1 operates on Temperature and calculates a new value placing that new value on the SR. The second iteration reads the value that was just calculated and operates on that value.....ETC ad infinitum ...
12-18-2014 08:48 AM
hey, crossrulz.
I get that the green lines/components are status'. What is the purpose of the second shift register, the green one. Is it used just to terminate unused connections?
12-18-2014 09:25 AM
thx Jeff! Im slowly getting to grips with this stuff, lol. I'd like to add some way of plotting the data on a historical chart. Anyone know an easy way to do this? I've used the principle that crossrulz used in his code, brilliant! I've been messing around with ideas for days, looking for ways to do this and I've hit so many brick walls ny nose hurts.
I'd like to show historical data of the 'current temperature' as it rises and falls within the set limits. Any ideas guys?
12-18-2014 09:50 AM
Use a chart. A chart keeps a history, so you just have to wire the current temperature into it.
The second shift register is to keep track of the state of the heater. That way the heater keeps its state when it is between the upper and lower limits.
12-18-2014 02:46 PM
@chilemad wrote:
hey, crossrulz.
No. You use this function for terminating unused wires.
From http://forums.ni.com/t5/LabVIEW/Simulating-an-inductor/m-p/937301#M420673
12-18-2014 03:21 PM
Guys, thanks for the help! Much appreciated!
12-18-2014 03:21 PM
12-18-2014 05:39 PM
Hey crossrulz,
I've been playing around with the code you suggested earlier, screenshot attached. It works superbly.
I want to add a case structure to add another mode of operation.
Say, the code you provided earlier is 'Automatic' mode; I want to add a manual mode that will, when 'manual mode' is selected, drive the temperature to the upper limit and hold it there until manual mode is deactivated when it will resume auto mode.
I've tried to force the heaters on with logic (an OR gate) but the temperature doesnt respond to the upper limit and rises indefinitely.
I appreciate all the help!
Mike
12-18-2014 08:46 PM
I don't see any OR function in your latest screenshot, so it is kind of hard to comment as to why it isn't working the way you want.
Actually, we need clarification on what you want. If you want the heater to be forced on, it is going to keep rising and rising and rising. I've never heard of a heater that is ON, but stops rising when it reaches a temperature.
12-18-2014 10:33 PM
@chilemad wrote:
Hey crossrulz,
Mike
Really, you just got "Functional code" and code creep is there already?
Wellcome to the LabVIEW developers life!
