10-17-2014 04:49 PM - edited 10-17-2014 04:51 PM
According to the help, the output named "values" should change its name to "value" once we wire a name.
This does not seem to be the case (See tip strip in image below) as tested in 2013 and 2014..
10-18-2014 01:57 AM
In LabVIEW 2013 it changes to value if only the name input is wired. Once you wire the default value, it switches back to values. 50% is true 🙂
10-18-2014 02:01 AM
Interesting...
