It depends on how much temperature range you want to read. It looks like the card is +/-10Vdc. You may be able to adjust the scaling on the input to a lower range. What type of resolution do you want in the temperature readings 10 degree, 1 degree, .1 degree?? You may need some signal conditioning/amplification for your signal. The card has 12 bit resolution. If using +/-10 volts input, take 20V/4096. This gives 4.9mv as the smallest readable signal change.
