importing text files and plotting graphs
pls i would the house help am relatively new in labview and i have a dead line this week ending. i want to plot time against 3 temperatures and also showing the initial temp of each column and end temperature with the duration of the graph in seconds the data file is attched time temp1 temp2 temp3 11:29:19,26.188,26.500,26.688 11:29:29,26.188,26.500,26.688 11:29:39,26.188,26.500,26.688 DELETE MESSAGE
(3,422 Views)
You did not attach your data file.  You might also want to attach the VI where yoiu have started working on your problem.
Also please retype you message so we can read it.  It seems like one long run-on sentence lacking capitalization, punctuation, and spelling which makes it impossible to understand what you are trying to do.
Have you taken the LabVIEW tutorials?
LabVIEW Introduction Course - Three Hours
LabVIEW Introduction Course - Six Hours
(3,405 Views)
Please i want to ask the house for help, am relatively new in labVIEW and i have a deadline this week ending. i want to import the text file attached into labVIEW , plot a graph with time against 3 temperatures and also displaying the values below the with an indicator for each. 1) initial temper of each column 2) end temperature of each column 3) duration of the graph in seconds the first column is time, the second is temperature 1. the third is temperature 2, the fourth is temperature 3, and thanks for the LabVIEW tutorial links.
(3,388 Views)
Data file is now attached. am sorry just joined the forum.
(3,380 Views)
(3,376 Views)
