01-28-2009 04:28 AM
Hi I am trying to use the imaq find circles Vi but keep getting the error.
-1074396080
IMAQ Find Circles
Invalid image type.
I am using 16 bits images should Find Circles work with 16bit. If not how do I reduce the size of the images to something that can be used.
Thank you.
01-28-2009 05:17 AM - edited 01-28-2009 05:18 AM
Don't hesitate to read help:
Binary image (8 bit) is required for IMAQ Find Circles.
So, use Threshold for getting binary image from grayscale (if possible). If not, then use IMAQ Spoke for obtaining coordinated of the circular edge, then you will be able to fit circle.
Andrey.
01-28-2009 05:38 AM
09-24-2015 04:39 AM
hello guys,
i am using imag find circles 4. it is showing invalid ROI. Please help me
09-24-2015 11:04 PM
@ponnuswamys wrote:
hello guys,
Did you read the 6 year old answer above? Did it help? If not, please provide more details.
09-25-2015 05:20 AM - edited 09-25-2015 05:20 AM
I think, the answer above will not help him, because it was about Image Type, not ROI.
In additional, there is no ROI input in IMAQ Find Circles (and no "imag find circles 4" function exists).
I guess, instead of IMAQ Find Circles the function IMAQ Spoke 4 was used. This function needed valid ROI, and it must be annulus, otherwise this will return "Invalid ROI" error.
09-25-2015 10:06 AM
thanks for the information
09-28-2015 01:24 AM
hello guys,
please help me for how to create for an image
09-28-2015 01:43 AM
I thought you already had an image?
09-28-2015 03:27 AM - edited 09-28-2015 03:33 AM
i have an image and i have to identifiy an object in that image for that i am using find pattern 4 VI block in LabVIEW 2013, but it needs a template image to identifiy an object.
so, i want to create a template for the image. but,i don't know how to create an template for an image. i am new to LabVIEW. so, please help me
