12-19-2013 10:52 PM
Hi Everyone,
In the attached VI I have got a problem on the mouse up event, I don't understand why after using the Imaq Extract VI only the image2 control keeps displaying its image.
Best Regards,
12-19-2013 11:25 PM
12-20-2013 12:56 AM
Sure,
Here it is, with the images to check software
Thank you, you are the one trying to help.
12-20-2013 03:06 AM
Thanks for uploading code in lv12 version.
Few suggestions to improve code. Please go through the design patterns available in labview to simplify code..
http://www.ni.com/white-paper/7605/en/
-If you want all the four indicator to have different images, you need to have four imaq create for each of them.
-Instead what you did is, you created image1 and image2 and you are sending or processing on the same images and it is main reason for confusion.(or this is how you wanted??)
-Please explain a little bit of what you are doing in the code, for me it was too much confusing.
12-21-2013 02:59 PM
Hi Thanks udka,
That solved it, one kudo for you,
What I don't understand though is why only Image 2 was actualized, as I had one imaq create for image 1 and image 2,
I don't really understand why you find it confusing as everything is managed by events, but I'll have a look at the link you sent and try to see what is missing in my programing.
Thanks a lot.
Best Regards,
12-24-2013 01:34 AM
