I have an old program running on Labview 5.0 where a camera is used to acquire an image. The image is displayed on a front panel without opening an image window. I don't understand why the same software running on Labview 7.0 and Vision 7.0 the image is opened on a new window. For this reason I have a lot of problems because the front panel is displayed in front of the image. I can't set the image floating because the program opens some front panels which are displayed in background of the image if it is floating.
can you post a simple example that can show this behaviour. I have no clue on what functions you are calling and it is very difficult to help without knowing what to look at. Thanks
Sorry Alessio, but unfortunately it isn't so easy to post the program because it is very big. Moreover I'm not able tu cut only the part relevant to IMAQ. Anyway I'm trying to do somthing, I'll keep you posted...
Ok, on top of this, I knwo you are already in touch with our Tech Support to discuss this problem. No worries and thanks for contacting us through the forums
