04-16-2014 07:36 AM
I connected a usb to labview using the IMAQdx. At first, it would run but would produce timeout errors after 5 pictures. Now, I manage to get the cycle to run 50 times but the image only comes out as a black screen. What could be the cause of this and how can I fix this?
04-16-2014 09:48 AM
I would like to take a look at your VI. Attach it as a file or take a screenshot and post it.
If you want people to help you, you have to situate your problem better then that.
Ruts
04-22-2014 07:43 AM
Thank you for your reply. Attached are two attempts that both produce the timeout error
04-22-2014 10:37 AM
Can you see the camera in NI MAX?
04-23-2014 01:56 AM - edited 04-23-2014 01:56 AM
I think his problem is solved in this post:
http://forums.ni.com/t5/LabVIEW/imaqdx-timeout/m-p/2823844#M826279
Guess that there is no problem with the connectivity of his camera. I'd like to ask you to mark it as solved if your problem is solved F.N.
