i want use google map api in VI . i tried so mutch to do it.i used google earth plugin and google static map but i need only google map api .
hi everybody
I am currently doing a program to display a map labview via several "red marker" in order to obtain a tracking of GPS data.
At the beginning I made a program for a single point (red marker) (with its latitude and longitude) on google map, my program worked.
Then I wanted to add other points on the map, so I changed my basic program by creating a for loop to display several points on google map, I put two arrays correspond to latitudes and longitudes.
Then I created two arrays, an array for the longitudes and an array for the latitudes to read a measurement file automatically without having to complete the array by hand.
Until here my main program is working but I have an issue :
Firstly when I'm using my main programe with "Highlight execution" my program works for many points
But when I run my program without "Highlight execution" , it's working juste for at least 20 points and if I add a file with so many points ( more than 20 points ) I have an error message
So I don't know why....
Someone could help me?
cheers
please find attached the error message
Message 31 of 134
(3,872 Views)
What does the error message say?
Message 32 of 134
(3,866 Views)
Hi cheers if you use 100 ~ 300 mili s delay in your for loop , this error will solved . Garousi
M.Garousi
Message 33 of 134
(3,854 Views)
hi Girousi
""you use 100 ~ 300 mili s delay in your for loop , this error will solved""
I have already tried this solution but without sucess.... 😕
have you got an other suggestion?
cheers
Message 34 of 134
(3,837 Views)
You still haven't told us what the error message actually says.
Message 35 of 134
(3,829 Views)
hi my LabVIEW is in deutch language , so I have tried to translate to english the erroe message:
information on invoking just-in debugging
instead of this dialog box you will find at the end of this release.
Exception Text ************** **************
System.InvalidOperationException: Collection was modified. Enumeration operation may not execute.
   at System.ThrowHelper.ThrowInvalidOperationException (Exception Resource resource)
   at System.Collections.Generic.List `1.Enumerator.MoveNextRare ()
   at System.Collections.Generic.List `1.Enumerator.MoveNext ()
   (g Graphics) at GMap.NET.WindowsForms.GMapControl.OnPaintEtc
   at GMap.NET.WindowsForms.GMapControl.OnPaint (PaintEventArgs e)
   at System.Windows.Forms.Control.PaintWithErrorHandling (PaintEventArgs e, Int16 layer, Boolean disposeEventArgs)
   at System.Windows.Forms.Control.WmPaint (Message & m)
   at System.Windows.Forms.Control.WndProc (Message & m)
   at System.Windows.Forms.ButtonBase.WndProc (Message & m)
   at System.Windows.Forms.UserControl.WndProc (Message & m)
   at System.Windows.Forms.Control.ControlNativeWindow.OnMessage (Message & m)
   at System.Windows.Forms.Control.ActiveXImpl.System.Windows.Forms.IWindowTarget.OnMessage (Message & m)
   at System.Windows.Forms.Control.ControlNativeWindow.WndProc (Message & m)
   (IntPtr hWnd, Int32 msg, IntPtr wparam, IntPtr lparam) at System.Windows.Forms.NativeWindow.Callback
************** Loaded Assemblies **************
mscorlib
    Assembly Version: 2.0.0.0.
    Win32 Version: 2.0.50727.4961 (win7RTMGDR.050727-4900).
    CodeBase: file 😕 / / C 😕 Windows/Microsoft.NET/Framework/v2.0.50727/mscorlib.dll.
NationalInstruments.LabVIEW110
    Assembly Version: 8.50.11.24514.
    Win32 version: 11.0.0f2.
    Code Base:
msvcm90
    Assembly Version: 9.0.30729.6161.
    Win32 version: 9.00.30729.6161.
    Code Base:
System
    Win32 Version: 2.0.50727.4962 (win7RTMGDR.050727-4900).
    CodeBase: file 😕 / / C 😕 Windows/assembly/GAC_MSIL/System/2.0.0.0__b77a5c561934e089/System.dll.
    Assembly Version: 1.5.5.5.
    Win32 Version: 1.5.5.5.
    CodeBase: file 😕 / / C 😕 Users / student / Desktop / gmap_mk / Map / GMap.NET.WindowsForms / GMap.NET.WindowsForms.dll.
    Code Base:
System.Drawing
    Win32 Version: 2.0.50727.4927 (NetFXspW7.050727-4900).
    CodeBase: file 😕 / / C 😕 Windows/assembly/GAC_MSIL/System.Drawing/2.0.0.0__b03f5f7f11d50a3a/System.Drawing.dll.
GMap.NET.Core
    CodeBase: file 😕 / / C 😕 Users / student / Desktop / gmap_mk / Map / GMap.NET.WindowsForms / GMap.NET.Core.DLL.
System.Configuration
    Code Base:
System.Xml
    CodeBase: file 😕 / / C 😕 Windows/assembly/GAC_MSIL/System.Xml/2.0.0.0__b77a5c561934e089/System.Xml.dll.
Accessibility
    CodeBase: file 😕 / / C 😕 Windows/assembly/GAC_MSIL/Accessibility/2.0.0.0__b03f5f7f11d50a3a/Accessibility.dll.
System.Web.Services
    Code Base:
jtpadbv2
System.Windows.Forms.resources
    Code Base:
************** JIT Debugging **************
To the JIT debugging (just-in-time) to activate, must be in the
Application configuration file or the computer
(Machine.config) jitDebugging the value in the system.windows.forms section are defined.
The application must be compiled with debugging enabled.
For example:
<configuration>
    <system.windows.forms jitDebugging="true" />
</ Configuration>
When JIT debugging is enabled, any unhandled
Exceptions to the JIT debugger sent on the
Computer is registered and handled by this dialog box.
Message 36 of 134
(3,821 Views)
Hi
I really need your help, because If I'm using my main program with "Highlight Execution " my program works and I can see the tracking of my GPS data but it takes a long time to be displayed each point
here are two  tracking I made , the green tracking there are at least 300 points and the red tracking there are at least 200 points, with Hight execution wich point by point , It take me at least 40 minutes for to display the whole points, , so image if I have 1000 points to display
Message 37 of 134
(3,805 Views)
here is two  tracking I made
thanks for your futur helping
Message 38 of 134
(3,804 Views)
Hi Garousi,
I saw and download your project to use de Gmap dll in Labview it's great.
But now I need to save a picture (.BMP) of map select area is it possible?
Diego Carvalho
Message 39 of 134
(3,793 Views)
Hi guys,
I need to save a image of GMapControl (Static map picture).
Someone can help me?
Best Regards,
Diego Carvalho.
Message 40 of 134
(3,765 Views)
