09-27-2014 12:27 PM
You need to put your data into the strings and save the values as default. Then save the VI and upload it.
09-27-2014 12:31 PM
09-27-2014 01:01 PM - edited 09-27-2014 01:03 PM
i am trying to achieve something like this.
but the input must be in binary. so i converted it into hex and concatenated all strings.
09-27-2014 01:08 PM
Attach the VI with your data saved in it.
Why does this screenshot show only 1 string, but your VI has 4 string controls?
09-27-2014 01:11 PM
So just to clarify, you have string data as an input that has binary data, correct? So this is an ASCII representation, something like "1001100110100011" etc.? And you want to display that as individual bytes, represented in Hex?
You could simply break the string up into byte-sized elements (8-chars), convert to a binary integer, like you did, and then just display the interger as Hex. You can right click a numeric indicator, and select Visible Items»Radix. Then you can select "x" to view the number in Hex form. That might be a simpler approach.
09-27-2014 01:25 PM
i have 4 strings as input with data in binary and i want an output like in the 4*4 matrix of screenshot.
to do this first i concatenated all those strings then converted in hex then make an array having 2 characters at every index and then convert it into a matrix.
but i am only getting first row of matrix
09-27-2014 01:56 PM - edited 09-27-2014 01:59 PM
Now that we have data, we can see what is wrong and can fix it.
The problem is you are taking your superlong string of 1's and 0's and converting it to a single U32 numeric, thus throwing away all the remaining data.
Convert the numbers into groups of 8 characters, and go through them in a loop to convert to U8 bytes. The regroup from there and convert to a Hex string that represents that data.
09-27-2014 02:42 PM
You are incrementing the subset by 1, so you get overlapping segments. I don't think this is correct.
09-27-2014 02:54 PM - edited 09-27-2014 02:58 PM
09-27-2014 02:56 PM
Dohh!. You're right. I missed i*8 going into the subset.
