04-02-2009 09:41 AM
Thanks alot, that works now. i'm still getting the buffer error on the DAQ assistant output, i've tried what i've read on other posts, but i'm apparently not understanding because it keeps giving me the error. i've attached the VI, not sure how to attach the DAQmx to the assistant.
04-02-2009 09:47 AM
04-02-2009 10:12 AM
04-02-2009 10:51 AM
I figured out how to save to a single file....the only issue is that the time column stays 0 all the way through. I appreciate all the help.
04-02-2009 11:32 AM - edited 04-02-2009 11:34 AM
Well, you've thrown away all of the timing information by converting to scalars for one write and in the other write to measurement files, you have Empty time column selected.
04-02-2009 12:09 PM
Ive changed them all to "one column only" for the "X value columns", it only records 0 in the X column. I'm not sure where you are talking about converting to scalars.
04-02-2009 01:18 PM - edited 04-02-2009 01:19 PM
Aargh! I just wrote a long explanation and then lost the post.
Anyway, I looked at what you are dpoing inside the DAQ Assistant for the first time and your problem is that you are doing a single point acquisition with each iteration. If you had multiple samples with each iteration, row 1 would be time = 0, row 2 would be that plus the sample rate (i.e. .5), row 3 would be row 2 time plus the sample rate (i.e. 1.0) etc. Each iteration creates a new segment and probably has some timing information in the header.
If you want to write a timestamp to each row and keep your single point acquistion, you will have to give up on the express VI and use the lower level file I/O functions. There are a lot os shipping examples to help get you started.
04-06-2009 07:57 AM
I have it all working now....thanks alot for all the help.
