hyber termial in labview
A framing error typically points to a setting that is not right.  Double check your serial settings.
GCentral
Message 11 of 18
(550 Views)
@KPRO wrote:
Attached is the screen shot of the LV. Thank you very much for your help.
Please post the actual code!  Many of us will not open an attachment in a propriatary format (Word docs can get easilly infected with viruses)
"Should be" isn't "Is" -Jay
Message 12 of 18
(540 Views)
1. 2 bytes is number of byte counted when reading (I did not set this)
2. I did try to set the input buffer larger 1045, but still reading only 2 bytes
3. Double check serial port setting but not much luck
Well, Thank you very much for your help, I need to do more research for this.
Khanh
Message 13 of 18
(539 Views)
I should've spotted this immediately.
The garbage returned in the VI should've prompted me to look at your hyperterm screen shot.  The baud rates are different.  Fix that and it should work.
Bill
CLD
(Mid-Level minion.)
Message 14 of 18
(522 Views)
Thank you very much. You are absolutely right ... It's working now
Message 15 of 18
(506 Views)
billko wrote:The baud rates are different.  Fix that and it should work.
You mean it really was a serial setting.  Wow, I sure wish I would have said something earlier.
GCentral
Message 16 of 18
(497 Views)
LOL you're rarely, if ever, wrong... but in order to figure out that you were correct, we had to travel a long and winding road... 😄
Bill
CLD
(Mid-Level minion.)
Message 17 of 18
(475 Views)
Hi
Please Check With this
https://decibel.ni.com/content/docs/DOC-16283
Regards
Prabhakant
Regards
Prabhakant Patil
Message 18 of 18
(458 Views)
