Shin,
i think you didn't attach the file due to the preview button which removes the file....
Nevertheless, if you create an html-report, you should get more than only one html-file. There should be a subfolder in the directory where the html-file is located which has the same name as the html-file. Within this folder, you should find all screenshots you need for the report.
hope this helps,
Norbert
Norbert
Expert: Geometry
