Ok so you believe that you can manually set it up?
OK then
2)enable the GPIB echo !
For each step that you manually carry out record the message shown on the screen
if necessary repeat !!!
SENS[1|2]:STAT ON; *WAI
SENS[1|2]:FUNC ‘XFR:S 2,1’;DET NBAN; *WAI
SENS1:FUNC ‘XFR:S 1,1’;DET NBAN; *WAI
SENS1:FUNC ‘XFR:S 2,1’;DET NBAN; *WAI
you should see one above following messages with regard to enabling S11 or S21
If you look at the block diagams of the vi in the library 8714 you will see the
appropiate SCPI commands.
All that you need to do is 'string' them together,with wait states, delays also.
OH You have not mentioned if you can actually communicate with the network analyser!!
1)First ensure that you can communicate with Network analyser
via GPIB. From the library use the initialisation VI. Make sure that you have manually set Network analyuser address ie 5
The following parameters have to be 'set'
Power, (also on/off), number of points, frequency start, frequency
stop, actual measurement mode(S11,S12etc)Centre frequency,Smith plot or
VSWR, complex plot
etc.There are numerous others but we'll get to them later
Remember that if you send a command via PC then it is necessary to
enable local mode if you wish to manually adjust anything afterwards.
IF you provide the specification (frequency, power level number of
points, markers, etc then i'll provide a general template which should
hopefully get you over the wall.
Meanwhile I suggest that you attempt to follow one of the example s in the guide
it should boost you confidence and allow you to explore the querks of HP 8714 network analysers menu !!
Xseadog
