01-04-2007 11:23 AM
01-04-2007 11:32 AM
01-04-2007 11:32 AM - edited 01-04-2007 11:32 AM
Can you send commands to the instrument using Measurement and Automation Explorer...
If yes, and it works, then I need more information to help you out...
If not, and you aren't familiar with MAX...
Open it up and go through "My System > Devices and Interfaces > Ports (Serial & Parallel) > COM1" and validate the settings on the screen. Once you are able to open a VISA session, open up the VISA test panel and play around with the write and read operations
(Much like Lynn and David I would suggest you check the baud rate of 300)
Hope this helps.
Message Edited by Steve.Briggs on 01-04-2007 12:34 PM
01-04-2007 11:45 AM
01-04-2007 11:52 AM
01-04-2007 11:59 AM
01-04-2007 12:03 PM
01-04-2007 12:05 PM
01-04-2007 12:12 PM
01-04-2007 12:29 PM
