how to use QT compiler when dll and header file requires QT preprocessors and headers
C++ dll have a header file that contains QT headers . while i include paths of those headers in Import shared library wizard more missing headers pops up. is there an efficient way to do this so that QT compiler can be used with labview so that dynamic link library can work in labview.
import shared library wizard:
(3,104 Views)
You landed on the LabWindows/CVI board but since you are programming in labVIEW you should post this question in the appropriate board
Edit: a quick search in the LabVIEW forum resulted in this question being posted today: are maybe you the original requester?
(3,101 Views)
