10-30-2015 03:18 AM
10-30-2015 12:31 PM
Hi ritesh,
do you mind to rephrase your question without creating links in the message body?
What have you tried so far? Which problems occur? Any error messages?
You should be fine using one of the DAQmx AnalogOutput example VIs from ExampleFinder…
11-01-2015 05:35 AM
Hi GerdW,
Thanks for replying. I am using pci card 6014 with connector board CB-68LP. i am getting the analog output when i am using my own code from pin 22 of CB -68LP, but i am not getting the analog output when i am using DAQmx AnalogOutput example VIs from ExampleFinder, though the code is running perfectly.
best regards
ritesh
11-01-2015 07:18 AM
11-01-2015 09:32 AM
Hi
the example uses ao0 pin and the code is running smoothly. i am not getting any error message . the only thing is that i am not getting the output from any of the pin.
11-02-2015 12:30 AM
11-02-2015 02:30 AM
yes but i didn't get anything.
