08-07-2008 05:26 AM
08-07-2008 05:42 AM
08-07-2008 05:55 AM
08-07-2008 06:08 AM
Hi Balaji,
So if you have an extended desktop across two monitors then I would say you had two options.
1. Within one VI you could simple design the front panel in such a way that it extends across both screens with the relevant information in the right screen. The fact that there are two monitors present is transparent to the applications.
2. With two VIs there is a property for front panels to choose which monitor they are displayed on. This is available by wiring a VI reference to a property node and selecting front panel window >> monitor. You then enter an id for the monitor you want it to be displayed on, this is a numeric e.g. your primary monitor will be zero. You can see the property node help page here.
I hope this is the information you are after.
08-07-2008 07:32 AM
08-07-2008 07:37 AM
08-07-2008 07:43 AM
08-07-2008 08:35 AM
I have just tested your code and it didnt work at first but it seems that perhaps windows doesn't zero index it's monitors so I would suggest trying references 1 and 2 and see if that works for you.
Also I attach your code using a this VI reference instead of open reference, this will ensure it will work on any machine as well as if you move the VI.
08-08-2008 12:19 AM
08-08-2008 12:49 AM
