03-22-2017 07:03 AM
Dear Friend
i want to show wave form start time when i run the program. and it should save wave form for at least 48 hours.
Asif
03-22-2017 07:52 AM
The Waveform Palette has a Build Waveform function (which is basically a Bundle-by-Name, a function you could also use). The Timing Palette has a Get Date/Time in Seconds. Combine these and you have (except for the 48 hours of data) your solution. Oh, don't forget about the "dt" component ...
03-22-2017 09:04 AM
And where is this waveform coming from? What is your sample rate? How many channels are you capturing?
