11-22-2005 08:56 PM
11-22-2005 10:09 PM
11-22-2005 11:39 PM
11-23-2005 12:13 AM
11-23-2005 01:13 AM
Thanks again for your kind reply.
i am using windows XP. i am trying to connect to a machine with two LAN ports, so i need two NIC cards in my system. i need exclusive connections via LV to each LAN port. any ways, looks like there is not such way in LV, though there might be a windows utility that can be called, i will be obliged if you are already aware of it and forward me the details.
Thanks and Regards
11-23-2005 11:10 AM
11-23-2005 12:08 PM
Anika, you reference is for server applications, it does not apply for outgoing connections as desired by modestt.
11-23-2005 11:08 PM
