how to secure BNC-2090A digital output wiring
Hi, I'm working on using the DAQ digital output to control the DAC digital input, but I have a problem on how to secure the wiring for the digital output to DAC. As when I plug the cable to the hole, it's loosely connected. Any suggestions on how to secure the wiring are appreciated.
Thanks in advance!
(2,554 Views)
Accepted by topic author simimasa
It's a spring terminal.
Try pushing in the orange tab with a screwdriver while pushing in the wire.  Let go of the tab before letting go of the wire and it should grab and hold the wire.  It may be a case of lifting up the orange instead of pushing it in.  You should be able to figure it out.
(2,548 Views)
It works. Thank you!
(2,545 Views)
