how to save the current access database as a new file with a specified name
what I am trying to do is after writing data to a public access file, save it as a new access file,
clear the public access file and write new data in it.
repeat the above process when requested by the operator.
which database function should I use to execute this "save as " action?
thank you...
(3,440 Views)
I'm not sure what DB tools you are using in LabVIEW however I was able to locate the following function that seems to accomplish what you asked about.
DB Tools Save Recordset To File VI: http://zone.ni.com/reference/en-XX/help/370016C-01/lvdatabase/db_tools_save_recordset_to_file/
As far as database applications go there are several examples included in LabVIEW some of which include SQL functions as well.
Isaac S.
Isaac S.
(3,416 Views)
Thanks for your reply, I hope to save the file as .mdb file (access database file)
I simply could not find the module that could possibly do that.
(3,410 Views)
Accepted by topic author lksusier
Why not just use the normal file operation functions ?
There you can copy your Access file, it just a file.
You can find the copy function in the palette : Programming -> File I/O -> Adv File Funcs -> Copy
(3,407 Views)
Why are you creating a new access database for each new iteration???
This defeats the purpose of a database which is used generally used to store multiple sets of data.
(3,402 Views)
I figured this out yesterday. I was just stuck with the Database operations and completely forget the most basic functions. 😞
(3,392 Views)
Thanks for your reply.
That was a request from a databse programmer, I was told the file created will make it convenient for him to import data to another database.
anyway, just want to get it done so I can move on to more critical tasks.
(3,389 Views)
