how to save daq data-in(from 2 channels) in 2-D arrey?
It's a little unclear what you need. If you have two scalars, you can use the Build Array function to create a 1D array and with another Build Array, append to an existing 2D array using a shift register. If you just want to append new values to a file, the Write to Spreadsheet function does have a 1D input.
Message 11 of 34
(661 Views)
I have 2 Analog information(voltage and angle) from Analog system to my DAQ card. i want to save this  informations in excel in 2 columns. column1: angle and column2: the voltage of that angle). thats all wich i want to do.
Message 12 of 34
(651 Views)
What is wrong with using the Write Spreadsheet file?  Show us your code so we can see where you are stuck.
GCentral
Message 13 of 34
(647 Views)
I don't have access to DAQ card now,so for example i choose 2 parameter (x and x^2).i'm going to change x manually and save x and X^2  in a excel file.and draw the chart. but i can't do it as easy as it seems to be ! i don't know what's the problem?  this vi is  attached .
thanks a lot...
Message 14 of 34
(642 Views)
I have problem when i want to enter data save-path   in file spreadsheet  ! i don't now what is destination file format?
Message 15 of 34
(635 Views)
The Write To Spreadsheet File saves the data in a delimited text file.  By default, the delimiter is a tab.
GCentral
Message 16 of 34
(633 Views)
thanx a lot . now i can see one result in txt format file.
but when i press Run button it wants a destination.i choose any destination even file.txt .but it wants another destination imediately and in every text file there is just 2 data (x and X^2). i mean i don't have series of data during changing the input number. the file is attached below...
thanks for your quick and useful responses...
Message 17 of 34
(624 Views)
Please turn on Context Help and read about Write to Spreadsheet File.
To avoid the file path dialog, use a front panel control outside your main loop or a shift register to pass the path from the first iteration to successive ones.
You have to tell the function to append as noted in the help.
Message 18 of 34
(620 Views)
I read about spredsheet,but i don't understand it . there is something about active X and,... . .But i became a little confused!!
how can i use shift register? do shift register let me to have all data in a page?
thanks
Message 19 of 34
(603 Views)
There is nothing related to ActiveX with the Write to Spreadsheet File.
If you do not provide a path with a front panel control or the file dialog function outside a loop, you will be prompted for a file path when the function is called. The function outputs this file and with a shift register containing the path, the next time the function is called inside the loop, the previously selected path will be used and you will not be prompted.
So, you can use a front panel path control, the file path dialog, or a shift register.
Message 20 of 34
(595 Views)
